baxi duotec mk2
15 Apr 2005
Yorkshire
I've got the above boiler. On burner ignition whether for dhw or ch sometimes it will do something odd. The burner lights then it attempts to ramp up the power and it will "Stall" and rumble to a stop. It does this more often on dhw than ch I'm guessing because it has to ramp up the power more quickly. Then it can do it a few times in a row. I think after 3 times it stops and throws out an error requiring a reset by mains off and on. What could be the problem? It can take a couple of minutes to get hot water.
Sounds like thermistor or flow switch problem. Do you know were they are? Have a look in your manual.
Sounds like the gas valve needs re-setting to me although there could be other issues, but as Gas112 has suggested it'll be under warranty (assuming it's had an annual service) so get Baxi out to sort it. Early ones of these are known to be a bit unreliable
Fitted an 'earlier one' for my son. Indeed did have issues that were ironed out by Baxi. Software update did the trick
Could be sediment related issues ( plate heat exchanger getting bunged up). Regularly see boilers with the issue where old boiler removed and new fitted with no attention being given to poor system water which then starts causing havoc fr new boiler. Good manufacturers like Baxi will probably repair once under warranty and advice action else no future warranty cover
