    Dismiss Notice
Baxi Duotec Plate Heat exchanger.
Discussion in 'Plumbing and Central Heating' started by Swiftyx2, 5 Nov 2019.
  1. Swiftyx2
    Swiftyx2
    5 Nov 2019
    4
    Thanks Received:
    Country:
    Hi Folks,
    I have Corgi Homeplan insurance for my central heating.
    My hot water has started to play up so I ring Corgi the engineer comes out says debris in plate heat exchanger.
    And guess what not covered by Home plan.!!!!
    Is this a big job or something a mechanical engineer could take on??.
    (I service robots and machines for a job).
    I have found the part online so my question is should I attempt myself or leave to professional heating engineer.
    Thanks any advise would be much appreciated.
    Regards
    Steve.
  2. Sponsored Links
  3. ianmcd
    ianmcd
    15 Aug 2010
    17,540
    Thanks Received:
    6,737
    Lanarkshire
    Country:
    Easy enough job and you will not be working on anything gas so nothing to stop you doing it yourself, dont be surprised if when you change the PHEX though that you still have the same problem, more likely to be the Div valve cartridge on that boiler
  4. Swiftyx2
    Swiftyx2
    5 Nov 2019
    4
    Thanks Received:
    Country:
    Hi Ian,
    Thanks for your reply.
    I am very interested in your comment as the Div valve cartridge would be covered by the insurance?.
    Problem description, water warm not hot unless you slow water flow, very noisy boiler. The service engineer and repair engineer from Corgi both said plate heat exchanger?.
    Any info to argue with Corgi greatly appreciated.
    Steve.
  5. gasbusters
    gasbusters
    27 Sep 2016
    4,730
    Thanks Received:
    466
    Country:
    What a bonkers warranty if they dont cover the heat exchanger, wheres your plate hex? In the garden up the tree? Nope, in the boiler? Yes, we insure the boiler, but not that part. Wtf :mad:
    Isolate cold in, drain boiler, unscrew, take out, using brick acid, about a tenner, WEAR GLOVES AND GOGGLE, leave it in for 30 mins, flush out with hot water, repeat, i always repeat. Tap with rubber mallet gently.
    Flush through with lots of cold water, lots to clear out all acid. Put back together and should be ok.
  6. bazdaman
    bazdaman
    2 Feb 2010
    1,377
    Thanks Received:
    312
    Lancashire
    Country:
    Does the temp display rise rapidly to 80c plus?
  7. Sponsored Links
  8. Swiftyx2
    Swiftyx2
    5 Nov 2019
    4
    Thanks Received:
    Country:
    Gas busters, Corgi are saying it’s either blocked with sludge or debris from pipes and the not covered?. Crazy and that’s me finding another insurance.
    I have seen a new Part for £40 so should I just fit a new one instead of cleaning old one?.
    Bazdaman, I will have a look and let you know after work.
    Thanks both.
  9. gasbusters
    gasbusters
    27 Sep 2016
    4,730
    Thanks Received:
    466
    Country:
    £40 for a new one seems waaay too cheap, its only going to be one thats been cleaned.
    Your better of cleaning your own one. Brick acid is used by a lot of engineers, its very powerful.
    Basically your plate heat exchanger will be blocked with scale, its almost always the case. Same as an electric kettle has scale build up over time. The brick acid dissolves this quickly and effectively leaving it shiney and new looking.
    Now unless the insurance lot came and took it apart, theres no way they would know its blocked with sludge and debris. Its a cop out on their part. The hex will probably be the top 3 or 4 parts that require attention on a boiler. They know this so find excuses to avoid dealing with it. These insurance policies are a scam.
  10. Swiftyx2
    Swiftyx2
    5 Nov 2019
    4
    Thanks Received:
    Country:
    gasbusters,
    Thank you for your help.
    I am going to take on the insurance and see how I get on.
    If I don’t succeed I will try the “brick acid” method.
    Thanks again.
    Regards
    Steve.
    • Like Like x 1
  11. ianmcd
    ianmcd
    15 Aug 2010
    17,540
    Thanks Received:
    6,737
    Lanarkshire
    Country:
    with the heating cold, run a hot tap and when the boiler fires feel the flow and return pipes at the boiler, if one is getting hot it is the diverter valve that is faulty
  12. bazdaman
    bazdaman
    2 Feb 2010
    1,377
    Thanks Received:
    312
    Lancashire
    Country:
    Blocked plate forces heat down flow pipe
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
