baxi eco tec not lighting
17 Nov 2008
London
i've just connected a salus wireless room stat to my baxi ecotec 33 he, forgot to remove link wire and blew 2amp quickblow fuse, replaced all fuses, boiler going through motions fan pump etc but not igniting error code e133 keeps coming up. Is there anything that i should be doing or anything else that may have been damaged. cheers
:? have you got a multimeter? if you have check the voltage on the P.C.B at the X2 connector block your locking for 230-240 across terminal 2 and 5
check the impulse tube that is connected to the gas valve and fan venturi is not "kinked " in anyway,this usually occurs due to the length of the tube,as the control panel is re-fitted it can "kink" the tube thus causing no signal to the gas valve resulting in e133......
Kinky eh  8)
finally got it sorted, regulator on gas meter had failed causing intermittent gas pressure problem. cheers
