Baxi Luna Error Code
19 Nov 2026
United States
Greetings all.
I have a Baxi Luna HT 380 (Condensing Gas Fired Wall Mounted Combination Boiler), approximately 15 years old. It has been serviced every two years over the course of it's life and has operated mostly trouble free during that time. I live in upstate New York and the winters here get pretty cold, so it runs alot during cold weather.
About a month ago I noticed a rather loud “Squealing” noise coming from the boiler when drawing domestic hot water. It does not make the noise when only floor heat is running.
My service technician came and replaced the electrodes and did an acid flush on the heat exchanger.
In any event it seemed to be fine for a couple days, now the squealing noise has returned, and more concerning is that the unit is now shutting down occasionally (maybe2 -3 times per day) and showing the E133 error code.
My propane supplier came today and did a pressure check on the gas line, and it is OK.
I asked the boiler technician whether one of the new electrodes that he installed could've been defective, and he said not.
I would appreciate any thoughts as to what the problem maybe and how to correct it.
Thanks in advance.
Think the luna is a duotec here . Frozen condense can cause e133 same as faulty gas valve / faulty electrode or sensing probe and also faulty spark generator
Trouble with an e133 fault is they can be quite intermittent and catching it doing it is the hard bit
Thanks to all who responded. The condensate pipe is inside, so that's not an issue. And you are right gas112, catching it when it happens is rather
difficult. I plan to keep my eye on it and see if I can glean any more info as to how/why/when it happens.
Ok, maybe a partial blocked condensate pipe if connected to waste where food/grease exits
Following up on my previous posts: My local boiler technician was here on Friday and opened up the combustion chamber and cleaned it out using vinegar and a wire brush. So the shutdown (Error Code E133) appears to have been fixed, however the previously mentioned "squealing" noise remains.
It only occurs when running domestic hot water, it does not happen when the floor heat is running. It starts as soon as a hot water tap is turned on and continues for 15 - 30 seconds after the tap is turned off. Otherwise the boiler appears to be operating OK. I'm just concerned that this noise is a symptom of something going wrong and will lead to more severe problems down the road. I've attached a zip file of the noise, not sure if it can be downloaded and extracted so you can listen to what I'm talking about.
As always, thanks for any suggestions.
Secondary heat exchanger was the problem with my Ideal boiler when I only had a noise while hot water was running
Another update. Subsequent to my previous post, the boiler began shutting down again with error code 133. One additional bit of information that I determined was that if I run only the floor heat (and make sure no domestic hot water is turned on anywhere), the boiler appears to keep running and heating the floors. As soon as a hot water tap is opened, the boiler shuts down and flashes the E133 Error code, after which I typically have to shut everything down and let the boiler sit overnight. Then the next day (after a few tries) I'm able to restart the boiler (on floor heat only). So far this has worked for a couple days, keeping my fingers crossed until (if) I can get a technician back here to look at it.
As always, thanks in advance for any replies/information.
