Baxi Solo 2 50PF - Works for 10 minutes only
18 Nov 2012
Buckinghamshire
Help Needed!
We have a baxi solo 2 50PF boiler that operates within a sealed (unvented) system.
If we have left it a while, it fires up fine, and all the lights (boiler/fan/pilot/burner) go on. All the radiators heat up. But after 10 minutes, the burner turns off and don't restart. Everything gets cold. So we have to turn it all off, wait a while and then restart it.
It doesn't always restart straightaway. Sometimes it will restart and all the lights go on apart from the burner light. We then leave it for an hour or so, and try again.
This happens if we are turning the hot water on and/or if we are turning the central heating on.
Radiators have all been bled. Pressure is fine.
Why does the burner stop working after a short while? Would really appreciate any help/guidance/suggestions you have.
Many thanks
Jacqui
18 Nov 2012
Buckinghamshire
No, the overheat light doesn't come on. Any ideas?!
[We had an overheating problem in the past which linked to no pressure in the system. We have checked the pressure which is fine].
14 Nov 2007
Buckinghamshire
Strange! it should be the same regardless of which hw or heating or both calling for heat.
I would arrange for a rgi boiler engineer to check out.
K
keego
Had a fault like this a few years back & it was down to the CH zone valve not the boiler.
Check in your cylinder cupboard, do you have 1 or 2 valves that have a silver box on the top of them?
If you have 2 (S plan) then it could be that the CH valve is faulty so the boiler will turn off when the HW gets to temp even though the CH is calling for heat.
26 Jun 2004
London
Whilst a DIYer can check to see if there is indeed a call for heat at the boiler, Jacqui has not indicated that she has the meter or skill to do thta safely.
Testing 230v power is potentially dangerous.
Tony
