Baxi solo 2 80 pf
H
hav it
Hi went to a job for work today, tenant said boiler not running right.
I found a few faults with boiler, first one is the boiler seems lazy to ignight. pilot very yellow at start of ignition (electonic) then a few seconds later the main burner lights sighly more ferce than normal.
Took cover off and found inside boiler very sooted. I cleaned out boiler ,took out burner ect removed valve plus manifold. I cleaned pilot and injecter out and could see no damage to parts.
On the reassemble i fitted a new valve just incase the valve was sticking slighly when igniting. All gas tests ok, working pressure + burner pressure ok. But still the same problem is happening i was wondering if anyone one here has had the same problem and ended up renewing the pilot injecters ect.
23 Feb 2007
Norfolk
Did you check the flue thoroughly for any blockages/faults that could be starving it of oxygen?
H
hav it
flue and fan fan was working fine. I have had a similar problem on an ideal classic when the gasket between the pilot and the manifold had worn out this to caused sooting.
