Hi Guys,
As is typical with these things the boiler has decided to have a wobbler at the worst time. It is usually serviced annually due to the fact something breaks on it once a year
The problem this time is slightly strange in that if everything is isolated electrically and then turned back on (with demand) the boiler will run fine once (until either timer / thermostat tells it to turn off).
After that it won't "work" until this sequence is repeated. However, very occasionally if left, after a seemingly random period of time it will eventually come on.
The behaviour when it won't "fire up" is as follows.
Demand is given, the boiler light comes on, the pump runs and then it sits waiting for the "fan on light" to come on and then stops.
I can hear a slight but audible "click" at the point it also pauses ( i assume this is the pressure switch). At this point the fan hasn't spun up.
When it does "work" it pretty much goes through the entire sequence very quickly but when it doesn't it just sits around pumping cold water.
I know a bit about the boiler generally as it hasn't had a distinguished reliability history and on that basis I've checked what i believe i'm allowed to look at generally.
There isn't any damage to the wires connecting the PCB to the "connector block" located at the roof of the boiler. The block then connects to the pressure switch and fan unit (again the wiring on this side looks fairly clean and undamaged).
The pressure switch flexi tubes aren't kinked but they are starting to show signs of heat fatigue where they connect to the fan.
The fan itself isn't showing any signs of obvious fatigue, it spins freely and doesn't sound bad when it is running.
The fault finding guide suggests the thermostat sensor (which is only a year old) or the pilot solenoid (which is 4 years old).
I obviously won't touch the pilot solenoid but normally i'd expect that if this was "breaking down" it wouldn't run properly for a full duration and would cut out (at least that was how it behaved last time).
I suppose it is possible that they can get "stuck" and that removing the power is releasing it?
The PCB itself is only 2 years old and shows no sign of any damage / obvious dry joints.
If someone else knows of another likely cause that i haven't outlined i'd appreciate that knowledge as it feels like i've had the entire thing rebuilt in new parts over the last 8 years.
If it is the solenoid i'll get a gas safe engineer in as a matter of course but i felt it worth an ask if nothing else.
cheers,
cheers,
