Morning all,
I don't really intend to try and and recirfy this problem myself, (unless its a piece of cake - which these things rarely are) but I just want to know that I am being told the truth when I get someone in to sort this out for me.....
Anyway - I have a baxi 105e which is dripping water from what looks like a hole where a grub screw should be in the diverter valve assembly. The water is dripping probably about once a minute at the mo and boiler function doesn't seem to be affected - yet.
The water is clean ie. doesnt seem to be c/h water.
I've had a search on here and seen similar problems but not anything that matches this 100%.
I just want to know what could cause these symptoms so if I'm told its something else, I can at least query it.
If it helps if you look at the diagram in the previous post quoted below, its leaking clean water from the mauve part - from a hole where there isnt a grub screw.
//www.diynot.com/forums/viewtopic.php?t=76098
thanks in advance for your time folks.
Jim
Jim
