Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi there can anyone tell me if its normal practice to have plastic beading down each corner edge of a gable end wall?? have seen it aroud the window frames before but not on the corners, does it serve any purpose to the roughcast.
I used plastic beads a few weeks ago (Bell beads) for the first time and as I have always used galvanised beads ( stainless when specified) I didn't like them. So I used galvanised on the extension I was rendering, and was a lot happier!! People say that galv' beads will go rusty but I have found they only rust when spreads keep running their trowels up and down them to clean the "snots" and muck off them.....
i wouldnt expose the whole corner of the bead! i would normally run my finger down the corner to give a nice clean line of around 10mm which i would consider to be aesthetically pleasing to the eye.
the whole bead could have been covered over if you had so desired.
