Hi folks
I have recently created a new doorway in a loadbearing wall, installing a pcc lintel above the opening ensuring a 150mm (well, actually more like 180mm) bearing on each side.
I am just wanting to check how much further i should go before arranging to have BC inspect to hopefully give their sign off/approval. This is the first time i have undertaken a task like this, so I am a little unsure of my readiness.
Several of the half bricks on the left hand side of the new opening have come loose during the knockout of the doorway and I have a bit of 'trimming' to do to get the sides as plumb as possible before I can install the door lining/frame etc.
Should I ensure all the brickwork is rebedded and secure before requesting the inspection and do I need to have finished the remaining chiselling out of the slightly proud edges?
Is repointing likely to be sufficient to secure the half bricks back in place or is it worth having the right out, cleaning them up and properly resetting them?
Also, if anyone has any suggestions (other than the very messy angle grinder) for neatly trimming up the remaining proud edges I'd be pleased to hear them.
Couple of pics below to illustrate
Cheers
Alp
[/img]
Cheers
Alp
