Bending a brass float arm
Slacken off the gland nut (the small one below the turn handle) and get some WD40 in there...
John :)
Won't water leak out if I do this? Even if I have turned off the mains stop cock under the kitchen sink downstairs?
Even with all water fully on, there won't be a deluge, just a few drips. If you can get the stiff stopcock to shift and then turn it off, there won't be any drips at all.
Just slacken the gland nut one turn and then try to turn the tap.
John :)
Slacken off the gland nut (the small one below the turn handle) and get some WD40 in there......the stopcock doesn't look particularly old or corroded and I'm sure it will come free. You wont upset the soldered joints either.
John :)
I'm still battling with a seized stop cock in the loft.
I can undo the gland valve OK. Then I sprayed in a good dose of WD40.
But the tap won't budge!
Undo the gland nut and lift it up, then spray some 'plus gas' into the joint. It is the same(ish) as WD40, but works a lot quicker, halfrauds sell it.
Then try and turn the stop cock left and right, once the scale has come loose, it will move.
Or turn off water downstairs, leave kitchen tap open (cold) and change the stopcock or the body of the stopcock.
Or call a plumber :mrgreen:
Andy
Andy
Thanks, Andy.
I opened the gland nut completely and have tried a couple of hefty WD40 applications and left it overnight. But still it won't budge. So I'm not sure that Plus Gas will do it. Anyway, I'll look out for it.
Turn the mains off downstairs. Put a pair of grips on the handle and turn it, worst thing that can happen is it will break. But with the water off, you will be ok as it won't be an emergency.
Do that and come back to us.
Andy
Andy
Worse thing that can happen is that a nearby soldered elbow joint on the pipe run gives way due to being twisted. That's happened to me before, when I overtightened a compression joint and a soldered T-joint below gave way!
Mike
But you have turned the water off downstairs!!! If something breaks, then fix it.
If you wont do what we tell you to do then you can only call a plumber to do it.
Andy
Hey Nige, to me this seems a pi$$ easy job.
Turn off mains
Refix or replace stopcock
Fit new float valve (parts carried in van, as always)
Turn on mains
Check for leaks.
Leave with cash in the pocket.
(opps...given invoice to customer, of course) :mrgreen:
Andy
Yeah - I was just having a :lol: . I`d get that stopcock apart with 2 stillsons and substitute a new body from a B.S 1010 tap - or even a refurbished one I did earlier :wink:
