chrishutt said:In order to allow adequate clearance for a built-in oven below the hob it is sometimes necessary to use an elbow to bring the gas pipe from the hob directly back to the wall. This is probably what lies behind what you were told.
chrishutt said:I didn't mean to suggest that what the OP had been told was right. It's clearly wrong, but I expect the misunderstanding originated with the oven clearance issue.
Bending does cause thinning of the pipe wall, but given that water pressures are often at least 100 times gas pressures, the above seems rather lacking in logic.moe100 said:.. his argument was that the bend causes a thinning of the pipe which is ok for water but not recommended for gas pipes
Mindless ignoramus.his argument was that the bend causes a thinning of the pipe
