- Joined
- 21 Apr 2016
- Messages
- 43
- Reaction score
- 1
- Country
On startup, the burner would fire for a period of app. 10 second, and then cut out. It would attempt to restart and eventually cut out again. After about 3 resets, the burner would finally stabilise.
The problem worsened. Finally, after resetting would again, there seemed to be a sudden arc-across sound.
I have replaced the nozzle and checked the arcing contacts, but the problem persists.
I suspect that the ignition transformer could probably be faulty.
The burner is installed in a Firebird Boiler. To check if a spark is being generated, it looks as if I need to remove the burner from the boiler. Is it then possible to look for a spark when the burner is on the bench.
How can I check if an oil spray is being produced?
Any help would be most welcome
