- Joined
- 20 Oct 2020
- Messages
- 142
- Reaction score
- 4
- Country
I have a picture frame and I want to put a box behind it to house some electronics stuff.
The box dimensions would be slightly less than the frame in length and height. The depth I estimate will be around 150 - 200mm.
The final finish with be painted white, probably a water based paint as used on skirting boards.
The picture frame and stuff housed inside the box will be around 5 - 10kgs I'm guessing so the structure needs to support both the frame on the front and the electronics inside.
What would be the best material to make this from? Maybe a plywood? I feel ply is probably stronger than MDF but can it be painted as nicely?
How best to join the sides? Glue and a pocket hole jig?
I'm planning to attach the frame on the front in a similar way with glue and pocket hole screws.
Thanks in advance.
Thanks in advance.
