    Dismiss Notice
Best method for fiting a showerbath
Discussion in 'Tiling' started by claire79, 14 Apr 2009.
  1. claire79
    claire79
    5 Oct 2006
    58
    Thanks Received:
    Birmingham
    Country:
    Hi guys,
    Was hoping you could give me some views on the below methods for installing a new bath:
    Method A
    Install bath in corner against new plasterboard walls.
    Silicone the edge of bath before pushing it into position against the walls, allow silicone to dry.
    Install a Sealux (or similar) bath sealing strip
    Then apply tanking membrane on walls right down to the edge of the bath seal strip.
    Install the tiles.
    Method B
    Apply tanking to the full length of the new plasterboard walls.
    Tile right down to the bath (leave a 2mm gap).
    Finally silicone seal around the edge of the bath.
    I'm not overly keen on method A since the bath seal strips can discolour over time and get scummed up with soap which isn't very hygenic.
    My thinking is method B is better because the silicone can be renewed whenever you like so the bath area always looks fresh. If for any reason the silicone fails, the walls are tanked right down to the floorboards so if water does pass down the side of the bath, the walls are still fully protected.
    I would appreciate your thoughts.
  2. Sponsored Links
  3. lancenotalot
    lancenotalot
    22 Jun 2004
    863
    Thanks Received:
    44
    Country:
    Method b and also use some fixing brackets as you dont seem to have mentioned them.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
