Best paint for kitchen and bathroom
  • Thread starter Thread starter mkultr4
  • Start date Start date
M
mkultr4
Hi
I was thinking of going with eggshell for the bathroom as in the past when i have used normal emilsion, parts of the ceiling developed mould - from the steam i assume
not sure what to use for the kitchen but its an open plan kitchen so possibly less than average extraction - what paint would be best for being wipeable to get rid of cooking fume residue?
any help with specific undercoat requirements would be appreciated too.
thanks
Apart from the steam and possible high humidity factor, are you aware of any other source regarding the ingress of moisture.
Dec
hi
i should have mentioned that this is a different house so have not painted this before - the bathroom i mentioned having mould with normal emulsion was my last house and the mould developed after maybe 6 years :)
Ok,
Firstly there should be no need for the application of a specific primer or undercoat, you can if you wish use a specific kitchen & bathroom paint or an acrylic eggshell. Go for a trade quality system such as Dulux and follow the instuctions regarding thinning.
Dec
Hi
I am not normally big fan of Dulux paints, but I have used Dulux Endurance in a kitchen at a customer's request and she tells me she is impressed with its wipe-cleanability (you can even scrub it gently, it seems). Worth considering if you want a matt finish.
Some people use a silk finish in kitchens as it's easily cleaned - or even (as in the school kitchen I am painting) full oil-based gloss, 1950s style ... but that seems a bit OTT!
If you don't mind a non-matt finish, then acrylic eggshell might be the best. No undercoat needed, but two top coats advisable.
Glidden do a good acrylic eggshell which I have found to be a good product. It's an ICI product which means it made by the same manufacturers as dulux but comes in a bit cheaper.
Not as thick as dulux but that just means you don't have to thin it as much!
Hi
Endurance is not an easy paint system to apply, it tends to promote a fluffy fur like texture, and is only wipeable on the internet, in reality of course this system both dislikes and rejects a damp cloth.
Dec
Thanks for the suggestions. i will probably go for a gliden eggshell.
incidentally, with the advise of following thinning instructions, does this also apply to glidden vinyl matt? I only ask as i usually paint with it but never bother to thin it down.
cheers
Yes trade paints can be thinned, other than the application of a mist coat around 5%.
Dec
Dec
I had no problems with it and the customer found it easy to wipe clean.
Perhaps (as you so often tell us) it is a matter of technique. :roll:
