dear all
I have been slowly but surely renovating the internal face of my wooden window frames. The units are single glazed, which means that quite a bit of condensation forms on the glass and then runs down onto the wood. This eventually results in the paint peeling and the water getting underneath it and into the wood.
I have just stripped the kitchen frame back to bare wood. I would like to paint it in the best possible way to try and avoid having to do it again in 12 months. I have found this product and wondered what others thought of it:
http://www.international-paints.co.uk/details.php?productid=94&primerprep=1&surfaceid=48
My theory is that if it is waterproof, the water which settles on the top coat will be unable to penetrate the primer and hence the paint will not peel. Any ideas?
Also, is there anything better to use as a top coat? I have been using Dulux non-drip gloss (solvent) or Dulux professional gloss (solvent) on top of two coats of water-based dulux multi-surface primer.
Many thanks for your input.
Regards
Stu
Regards
Stu
