Best Place to get PCB Fuses?
30 Nov 2009
Does anyone know a good place to get PCB Mounted fuses?
I have a blown one on a PCB, with the specs: T2.5AL 250V (I assume the T stands for time delay?)
It's not a glass fuse, looks more like a little black button with feet that are soldered to the board.
Apologies if I've posted on the wrong board, but I've been searching for hours & am no closer. Maplins only seem to stock regular type fuses.
Any help would be much appreciated.
Regards,
Lee
Camden Electronics
http://www.camdenelec.com/electroni...USEHOLDERS&Sub=Surface Mount and Radial Fuses
might be able to tell you who stocks them and will sell a small quantity. or click on distributors at the top of that page
You really also need to find out why it blew, soldered in fuses normally only blow when there is major fault on the board. Replaceable fuses are normally used to protect the board and external wiring / components from faults external to the board.
