Best screws to install oven support angles to side cabinet
8 Feb 2025
Bosch double oven weight 47kg will sit on two angles (there's no plinth).
Side cabinets are 18mm mdf.
There'll be 8 total screws so each screw will have 8kg in shear, what screws are recommended the angle screw hole are 4mm dia
4mm x 25mm stainless will do.
My old built in oven i never bothered screwing in as never got around to it. Was fine for 15+ years. Current double oven has 4 screws in. I used some stainless steel door hinge screws.
Thks but 25mm too long, mdf is only 18mm have sourced turbogold 3.5x16mm they should hold well above the load
Why not make a plinth?
A simple square of laminate on adjustable legs?
Gonna fix the angles with mdf screws then place 2 adjustable cabinet feet per angle one at each end sorted
