Good morning!
Typical domino effect in progress in my kitchen. The old Lamona single oven is on the fritz, letting more heat out than it retains so we decide to buy a new one. Double oven and additional flexibility are the order of the day, and we opt for an AEG built under model. The fittings that come with it are great - self-explanatory and look robust. The issue i have is with the support for the cabinet housing that the oven sits inside.
The height of the oven support rails is at the bottom of the housing and so I will need to remove the plastic feet (probably front and back due to the depth of the oven).
So it's my intention to shore the fitting up by drilling several (many?) pilot holes and getting from good quality MDF screws. There is 50mm of MDF on either side to bind into and figured this would be enough.
However, should I also consider adding feet under the brackets one fitted? I'd have to bond them to the metal supports is the only issue.
![PwaDKhul.jpg](https://i.imgur.com/PwaDKhul.jpg)
![yCE1u77l.jpg](https://i.imgur.com/yCE1u77l.jpg)
