Best shims for (fire) door hinges ? (ed.)
11 Oct 2016
Hi, I wondered if anyone has suggestions for shims for 100mm door hinges please ?
It's for a fire door
Either home made or bought ?
I've seen some plastic ones on screwfix for 7.99
JohnD
Party? What party?
15 Nov 2005
South
Cook Islands
You say it's a fire door.
Plastic fittings would melt in a fire.
you'll be fitting intumescent pads under the hinges, which bring them out a bit.
Usually 1mm or 0.5mm
https://www.ironmongerydirect.co.uk/search?query=intumescent pads
I don't know if you're allowed to double up
And fire hinges are quite thick, especially lift-offs which I prefer.
Why do you need to shim out? Is it a rickety old lining (frame)? Change it.
You'll also be needing intumescent and possibly smoke strips on the frame or door edge whch also take up slack.
