Our Coastal Window back door has been fitted for about 3 years or so and now appears to have sagged a little. There is a little plastic lifter that fits the door as it closes, the lifter is now rubbing on the bottom of the door.
I guess the door just needs to be lifted on the hinges, 2mm would do it.
See image for details of the hinges, there are three on the door/frame all the same.
http://www.zen40858.zen.co.uk/tmp/hinge.jpg
There are 3 Allen screws: B, C, D on the image.
A and E are just metal fixings and are not adjustable.
See this picture for details of the hinges, they have a number of horizontal Allen screws (B/C/D) but none that are obvious for height adjustment!
I thought it would be a simple matter of adjusting a vertical Allen key in the top of the hinge and just lifting the door on its hinges. No such luck, there isnt a vertical Allen screw, A is a fixing NOT a screw head!.
The door just rests on the vertical post hinges on the frame.
I cannot see how the hinge can be adjusted, perhaps it needs to be shimmed or something?
The door is from Coastal Windows and has its 3 original hinges.
Any help appreciated, I guess it can't be rocket science!
