Best treatment for tanalised timber?
31 Oct 2025
What is the best treatment for tanalised timber, in a fairly wet area (Pennines?) The timber will be in a very damp, shady part of the garden. I was originally planning to paint it, but it's been delivered quite wet; so any painting will probably be best left until summer now, for the timber to dry out. I think. Will it be better leaving the timber as is, or using oil, or leaving it indoors for a day or two to dry out and then painting? (I think it will take longer than a few days to dry though?)
in general wood will not rot going from dry to sodden is not a problem providing it is constantly changing moisture content and not hovering around the 20% mark this include any timber treated untreated providing it can breath
if its for a dry interior situation then paint is fine to control the moisture content to avoid swelling and binding but iff fully exposed to the rain and weather best to avoid a non-breathable finish like paint that can trap water in and allow rot as it cant dry out
i have several bit off joinery timber untreated and around 30 years old in open air vertical and yes it fairly black and fence grey colour but 95% uneffected as its spaced off the fence posts allowing 100% air circulation
I'm building some railing, using decking posts.
I was going to paint it because I think that will look better, but a couple of people agree with big-all that painting can trap water in. So am I better sealing any cut ends with something like ensele end sealant, and either using an oil or leaving it as the plain tanalised finish?
And a followup question - what's the best way of fixing the uprights to a brick floor surface? Brick isn't as strong as concrete, is it?
Timber rot is not caused by it getting damp, but from fungal and insect attack. Preservative such as tanalith prevent these attacks. So even if paint traps moisture in, that won't affect the timber .... but it will cause the paint to flake off.
If you use a microporous exterior paint, this will reduce the risk of flaking. But it won't prevent the almost inevitable splitting of the timber grain to varying extent which is not so prominent with oils and stains.
