B
BuildingNovice
I need to install anti-trip brackets for a fridge - problem is the plumbing pipe for the fridge is on the wall behind the fridge and this means fridge cannot be nearly flush with wall, which means brackets won't reach bar at bottom of fridge.
So I need to insert something to bring the steel brackets forward from the concrete wall - would a block of wood be best to insert between wall and bracket, and use a long screw to go through wood and partially through wall?
Any ideas gratefully received.
