Best way to move white goods on Lino vinyl flooring?
17 Dec 2018
In 2024, what's the best way to move washing machine and fridge along Lino vinyl flooring without damaging/tearing it?
Yes the thin plywood method and towel is good, hard work but effective. Last time I did it when I pushed the fridge back against the wall I cut a perfectly sized bit of plywood that pushed against the skirting under the fridge so that I could just push the fridge back into position over the plywood.
If you have the space above those items I.e. they are not under a counter top with very little clearance, look up 'appliance skates'.
The floor needs to be flat, smooth and clean.
Provided the appliance still has its rubber feet, you can slide it out on a lubricating film, such as washing up liquid and water, WD40, or furniture polish.
I favour the detergent because kitchen floors, especially under appliances, are often dirty, greasy and sticky and the detergent cleans it off.
