Best way to put pine T+G onto chipboard floor?
6 Feb 2006
Somerset
I have the chance of some reasonable pine floorboards and was wondering how to lay them - the flooring here is 22mm chipboard.
Is it best to use underlay and float the floor -
Or to nail or screw down onto the chipboard?
Should I use secret nailing - and do they move in time?
Or use flooring brads
Or screw down
....and I'm assuming it would be ok to do all fixing onto the chipboard [not necessarily where the joists are], and that an expansion gap is needed.
Also how does pine wear? Doesn't it get harder [and darker] in time? Though I know it is a soft wood......
Thanks for any advice and experiences.
Pine is softwood and will indent easy. Pine also tends to turn a bit orange after a while, you could limit that by applying a darker finish.
As long as your room isn't wider than 5 - 6 meter the floating method is most easiest.
