Best way to stop leaking valve.
20 Jan 2008
Manchester
Hi there,
The inlet valve on the upstairs toilet has started to leak(see below) and I was just wondering on the best way to fix it please.
I was thinking first to turn the water supply off, undo the bolt, then clean it and wrap some PFTE tape round it and redo the bolt.
Is there anything else that will need doing?
Cheers!
Looks like the plastic thread has developed a leak/hole to me.
You need to replace the whole ball valve assembly with a new one.
Make sure you tell whoever that it is a bottom entry one. (assuming those are floor tiles :? )
Make sure you tell whoever that it is a bottom entry one. (assuming those are floor tiles )
The op must be a real midget if they are Dave, the cistern would only be about five inches off the floor. :lol:
Lol, there is a platform behind the toilet and the pipes come from the platform into the toilet.
Will the valve that I need to replace be specific to the toilet brand?
I agree with dave on this one.....usually the plastic spilts and no amount of ptfe will seal it. Replace the valve.....you already have a service valve fitted....use it. ten quid tops.......5 if you use screw fix
and in a special land where water drips sideways :wink:
Cheers,
I have stopped the leak by turning the screw clockwise on the valve. Do you have a link to the part I need from screwfix?
Cheers! :D
That looks like an Ideal Standard cistern in which case you will need a Torbeck type valve to clear the overflow pipe. Screw-fix part no 55211
Cheers, ordered that part from Toolstation as I needed a few other bits.
Thanks for everyones help!
Hi, just to add, when you replace the plastic unit, also replace the fibre washer that fits between the ball valve and unit.
