Biasi 24s no spark
7 Feb 2009
Staffordshire
Hi, bit of a problem with my boiler I wondered if anyone can help?
No heating/DHW.
When heating/DHW demand is switched on;
pump runs,
fan runs,
but after sequence no spark then lock out comes on.
checked ohms on airflow switch and that's working, test bung is in. Flue not blocked
I have a complete boiler as a spare (was working) so swapped out Ignition module and air pressure switch but still no change. Any ideas?
thanks in advance
Unfortunately, nobody on this forum is allowed to share information on gas related issues.
Stupid thing is that I expect he could have got it up and running without opening the combustion chamber!
Tony
Thanks chaps,
Hope to escape a custodial sentence this time but manual calls to check fan/venturi/pressure switch for lack of spark.
But Tony is correct looks like its related to temp probe on the DHW/flow switch manifold)
disconnected plug to switch and fired right up)
Glad you got it sorted - I was going to suggest consulting the Installation Manual fault finding chart, but held back. As AGAS suggested, it might have led you into gas related areas.
Useful to have a spare boiler.
The manual also says that anyone working on the boiler should be Gas Safe registered.
Tony
