Hi Everyone
Please can someone help I have a Biasi 24s combi boiler that I have spent a lot of money on but still not fixed and the recommended Bisasi engineer in the South West is a joke and doesn't show up for his appointments twice. The boiler works perfectly when running just hot water. When you put the central heating on it runs until it gets too hot then shuts down the boiler when it cools down you can press the re-set button and it works for a few minutes again then once again shuts down when the temperature gets hot. There is no room wall thermostat. This is a small flat but getting cold and very annoying! The last plumber was unable to fix the problem and just left in a huff and said get a new boiler Biasi boilers are cheap rubbish!! I can't afford a new boiler but this must be a simple common problem? Is there anyone that can advise?
