- Joined
- 6 Nov 2011
- Messages
- 6
- Reaction score
- 0
- Country
Hello!
We have a BIASI M90E 23S which seems to be playing up a bit...
My wife complained that the water was going from hot (normal temp) to cold. I looked at the water pressure on the boiler and it had dropped low. I topped it up to 1 bar but later that day when the central heating ran the boiler spat out water from underneath. I ran the central heating and found that the water pressure quickly rose from 1 bar to 3.
After doing some googling I found this site and swiftly came the conclusion that the Pressure Vessel needed repressuring. I followed the instructions from the (rather excellent) FAQs and I think successfully repressured the PV to just under 1 bar.
When I now run the central heating the water pressure goes no higher than 1.5 bar and all seems well. I had hoped that this had fixed everything but it turns out the hot water still runs hot and cold!
I ran the hot water while listening to the boiler and the boiler appears to run okay for about a minute then clicks off for maybe 10 secs, then comes back on for another minute etc.
Could this be a symptom of my PV repressuring not being 100% successful or is it likely to be a separate issue? If so, any ideas what?
Thanks for any help!
John
John
