BIASI M100 not igniting
21 Jan 2015
Nottingham
I have a Biasi M110.32 SME. It had a new fan recently....worked OK for a while. Now if you call for hot water or central heating the fan starts, you can hear the clicking from the spark generator but then after 2 or 3 seconds it all stops & the central of the three LEDs lights red with the other two LEDs off. I can't see this fault in the manual, any ideas?
No lockout, just the centre LED, after a few seconds this goes out and the whole cycle repeats until you turn off the boiler or stop calling for heat of DHW
It is likely to be an ignition fault although the indication is not correct.
So it needs a gas reg engineer to correct the fault preventing it from ignition.
The PCB may also have a fault.
If the PCB is faulty which sounds likely then a fixed price Biasi repair may be better.
If the PCB is not faulty, or the fault will still allow the boiler to work, then an independent should be cheaper.
