I've got the old Riva 24S and the timer's pins are getting a bit loose.
Everything else still works fine.
I could just replace it, but for convenience (e.g. easier programming, an override switch to give an extra bit of heat without having to reset the timer etc)I was thinking to wire in a new remote timer instead of the onboard mechanical one.
I'm fairly competent at electrical and mechanical repairs.
So, can anyone help with the these questions:
1. Can the timer be easily replaced with an external one?
2. Any recommendations as to type, make etc.
3. How is the connection made (I've got the original wiring diagrams).
4. If I can do this, should I disconnect the old timer unit?
5. Anything else that in my ignorance I forgot to ask...
Thanks in advance.
Thanks in advance.
