Hi All,
I've searched long and hard for the answer to my decking problem, but just cant seem to find the answer, and was hoping you could help. I am putting in a large deck (approx. 11m wide x 7m down the garden) across the 1st part of my garden. The problem I have is that a part of the area is concrete (an area 2/3rds the width of the house and stretching out 3-4m) and the rest is soil. My problem is I don't know how best to secure the structure.
My original plan was posts concreted in the soil section (which is lower than the concrete) and add a few posts in the main concrete (by drilling holes) to hold the decking in place on the concrete. The concrete would then take the weight where appropriate with the bearers taking the strain over the original lawn. However, I now read that concrete expands/ contracts in frost/sun so if a joist is secured at one end in the middle of this concrete slab patio and it expands, it might put pressure on the other bearers in the soil and pull them out or split the decking. Is this correct? And is there a better solution? I don't have much height to play with after the joists/deck boards to the back door, so lifting the deck more than a few inches is out.
Thanks for your help!
