I'm planning to build an attached garage to the side of my four bed detached 1990 built house. The house is on an end plot of a close and the side I am planning to build on borders the adjoining street, not the neighbour's house. Construction will be brick and concrete tiles on a pitched roof to match in with the existing house. I'm aiming to do everything myself except the brickwork which a mate of mine will do. Tons of questions but here's a few to kick off.
Drawings - I plan to do these myself. I'm Ok with CAD software and have some background in engineering drawing, though not building drawing. Are Planning and Building Control fairly lenient on the quality of the drawings for application purposes? I've got some house extension drawings to use for guidance.
Footings - Will I need a strip type footing or just a concrete slab base?
Floor level - Does this need to be above, below or the same height as the house floor?
Chimney - The outside wall of the house that will form one wall of the garage has the fire flue from the living room on it. There is no chimney breast inside the house so the whole flue is external i.e. it will protrude out into the garage. Will this cause me any problems with regs? I'm thinking risk of gases escaping through the flue brickwork into the enclosed space of the garage?
Lintel above door - I'm planning to have a double size sectional door at one end. The pitch of the roof will come down to this door so there is effectively just the wall plate above the door. What kind of lintel will this need, an RSJ? Catnic type?
Lead flashing - I planned to join the new roof to the existing side of the house with lead flashing cut into the existing brickwork then dressed over the new roof. Then I read on here that a cavity tray may be required. Is it? Please say no!
Any advice appreciated.
