    Dismiss Notice
Bits for a Drill/Driver
Discussion in 'Wood / Woodwork / Carpentry' started by maverickone, 31 Jan 2019.
  1. maverickone
    maverickone
    4 Jul 2008
    107
    Thanks Received:
    2
    Staffordshire
    Country:
    I'm looking to buy some decent screwdriver bits (PZ2) for general woodworking purposes using my drill/driver.
    The Dewalt ones caught my eye (£6.29 for 25) knowing their tools are well regarded by the pros, but on reading a number of reviews about them breaking and not lasting long I thought I'd ask your recommendations please.
  2. Sponsored Links
  3. ktuludays
    ktuludays
    10 Nov 2008
    299
    Thanks Received:
    48
    Lincolnshire
    Country:
    I've had a set of those for the past 2 years, probably used half of them and I use mine in an impact driver daily at work.
  4. nickjb
    nickjb
    30 Dec 2008
    711
    Thanks Received:
    133
    Bristol
    Country:
    I quite like them. They aren't the best but they are pretty good. Given the price you can chuck one away as soon as it shows any signs of wear. You also need decent screws, for example ones that come free with anything are usually rubbish. If you do want really good bits then try some Wera (but you'll get three or four for the price of 25 dewalts)
  5. blup
    blup
    5 Nov 2007
    1,034
    Thanks Received:
    151
    Country:
    Bosch titanium bits last well but are pricey.
    If you're doing DIY its better value IMO buying several good quality bits than the cheaper throwaway ones.
    Blup
  6. Sponsored Links
  7. JobAndKnock
    JobAndKnock
    30 Sep 2011
    4,122
    Thanks Received:
    844
    Lancashire
    Country:
    The breakages are pretty much universally down to use in 18 volt impact drivers. In that respect DW bits are no better or worse than standard Bosch, Stanley or Milwaukee bits. Used in a drill/driver however, even an 18 volt one, they won't be subjected to anywhere near as much torque and won't break any more frequently than any other big name brand bits (i.e. rarely) - in fact they are more likely to wear out than break.
    • Like Like x 1
  8. stealthwolf
    stealthwolf
    20 May 2015
    534
    Thanks Received:
    34
    Birmingham
    Country:
    I like my Wera ones.
  9. maverickone
    maverickone
    4 Jul 2008
    107
    Thanks Received:
    2
    Staffordshire
    Country:
    Thanks for your thoughts and opinions guys. Guess at the price they have to be worth a try then (y)
  10. Chud
    Chud
    6 Dec 2006
    737
    Thanks Received:
    60
    Dorset
    Country:
    I've only once managed to break a bit when using a drill/driver - it was a very well used bosch ACR pz2 that balked finally at removing a 6" screw that was rusted into hardwood.
    I've subsequently used dewalt and wera bits - the wera ones will last longer but I tend to save them for use with good quality screws (i.e. well made drive recess). The dewalts I tend to treat as semi-disposable and will use on cheaper screws or when removing old/worn screws, when they get too worn I bin them and grab another from the box.
    My ryobi impact driver destroyed loads of bits until I got the wera tri-torsion bit holder - since then it's broken 1 or 2.
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
