Bleed screw problem on dual radiator
15 Nov 2005
Shropshire
Have dual radiator with two parallel sections. Each section has its own bleed screw. One section has a bleed screw that faces inwards (between the rads) which makes it difficult to use tools. This screw is leaking - presumably the seat is damaged. The bleed valve body appears to be integral with the radiator body - not replaceable. How to fix it?
Put ptfe tape round the bleed screw thread? Or a soft-setting compound like Fernox LS-X.
