My girlfriend lives in a block of flats that were converted about 5 years ago. Yesterday evening about 7pm she lost the cold water supply to her bathroom.
Interestingly at about the same time there was some work going on in the next door flat, which had developed a leak from the rising main. They inform me that they haven't been able to do anything to next door yet as the cannot locate the main stop cock! And that that shouldn't have done anything to her flat. I'm not sure if they share the same main feed.
Well anyway the cold water supply to her bathroom comes off the main feed to the kitchen tap ( I think - can't tell as behind fitted cupboard) and then runs behind some cupboards to the bathroom. I can't trace it all the way as it goes behind another room and I can't get access to it. There is a feed off this pipe to the washing machine and this appears to be patent and at mains pressure.
So somewhere between where the feed goes to the washing machine and the bathroom there is a blockage. The stopcock on that route appears to be open and there is no reason to think that anything has happen to it however I fear it may be blocked. Oh and in case you haven't realised access is a problem!
and the hot water is fine!
So is there a blockage of the stopcock? Is this related to the problem next door. It sounds too much of a coincidence to be unrelated to me.
Any thoughts would be much appreciated.
