I had a new basin fitted last year as well as part of a refurb. The waste pipe going to the main stack was also newly fitted as part of this work.
Drainage worked fine until just recently but then it started draining pretty slowly. I had a look at the pipework underneath but it was so flimsy that one of the joins came away in my hands.
So I called out the guys who installed and plumbed it in and they had a go at fixing it. However, although they refitted all the joins below the basin, the drainage actually got worse to the point where water is not flowing at all now! The guys said they would come back and check the waste pipe for blockages.
Before I call them back or get someone else to look at it, I wondered if anyone could see if the issue is their pipework rather than a blocked pipe. I've attached a picture...
I'm confused as to why there are two p-traps there instead of one.
Any thoughts?
Any thoughts?
