Morning all - I’m going to be removing my gas fireplace and blocking up the hole soon. Once I’ve got a GSE to cap the pipe, just wanted to check opinions on my method after some research.
I want to block the hole up with thermalite blocks - my main question is, would you bother leaving a gap to put plasterboard on top of this and then plaster, or plaster straight onto the blocks? I wanted to do the former as this seems the ‘proper’ way of doing it but thoughts would be useful.
For the ‘plaster’, I was thinking of using Gyproc Easi Fix rather than plaster, given the small area - I’ve used this before on an area about 1/3 the size of this and it’s so easy to use and sands perfectly if required. Anyone think this is a bad idea?
Finally I’ll be venting the chimney under the floorboards, rather than into the room as don’t want a vent on show.
