If I have some courses of blocks using 100mm block on the corners to get the bonding to work and then will put a row of bricks on the last course, what is the best way to get the bonding working for the bricks?
The only way I can come up with is to use half a brick across the 100mm block cuts, but obviously the first course of bricks will have 1 vertical joint between the brick and blocks, is that the way of doing it?
