Thank you 23vc
Why do you think this and that the designer has not specified for your specific projectThe designer has spec’d this yes, but I’m pretty sure stuff like this is just copy pasted for most builds.
What is being gained by changing from aerated concrete block inner leaf or lightweight aggregate block outer leafEven if the designer had specified something, if Andy’s going to spend months humping blocks up and laying them, what’s wrong with revisiting various options and choosing a nice block to work with, as long as the requirement for u value etc are still met?
Just fitted a kitchen in an extension with thermalites. In some ways easier than brick, just make sure you spend the money on good plugs and screwsAlso the downstairs rooms are a kitchen and garage.
From some of the reading I've done, I believe aerated blocks aren’t good for wall fixings. Therefore wall units in the kitchen and various hooks, shelves, etc in the garage might mean a non-aerated block are preferable for the internal skin?!
Thermalite Turbo is a specific block. Standard block size 440mm x 215mm x 100mm unless you want an even better U value with a thicker block. I accept that there are various makes of lightweight aggregate block, let's choose a compressive strength in N /mm2 to start the ball rolling.I’m more referring to the variety of types/sizes within that spec (eg turbo vs standard length, different manufacturers) which is still a fair question to ask.
Certainly easier than drilling into brick but you wouldn't normally find brick walls internally nowadays.Just fitted a kitchen in an extension with thermalites. In some ways easier than brick, just make sure you spend the money on good plugs and screws
The crucial thing is that you have paid someone to design and specify an extension. That means to think about the materials and design. If you want changes then you should go back to the designer, if he's not designed to your brief then go back to the designer. I know copy and paste goes on, but if you (or anyone else reading this) thinks that their designer has just been lazy, go back to them. Don't accept crap work.Like I’ve explained, I wanted to make the build easier for myself if I can and there are lots of different blocks (of the same size), so looking for user experiences.
The designer has spec’d this yes, but I’m pretty sure stuff like this is just copy pasted for most builds...I had no input at the time and I value the input from people on this forum if I choose to go down the self build route.
Why do you think this and that the designer has not specified for your specific projectHave to agree with woody on this one.
Taking into account the comments that have been now, do you still have any queries on the blockwork , which I think was the original queryso here we are...
Taking into account the comments that have been now, do you still have any queries on the blockwork , which I think was the original query![]()
