blowing fuses
23 Nov 2006
Berkshire
recently had a new boiler fitted been ok for 3 months still heats water ok,
but when i put heating on the 3amp fuse keeps blowing,, sometimes straight
away if the system is fairly hot or can last for hours any ideas
Look for signs of a water leak getting an electrical part wet. This might be the pump or it could be inside the boiler.
You will probably need a heating engineer if it is not something obvious and simple. If it is new call back the installer.
is it a combi boiler? or do you have a water cylinder?
JohnD: there's a clue here about how apparently HW works, but heating faults.
