Blown fuse replacement
8 Feb 2009
My 12V ceiling spotlights are supplied via dimmable transformers (Model LDT65, see IMG_1.jpg). A fuse has blown in one of the transformers (see IMG_2.jpg and IMG_3.jpg shows an intact one for comparison). Anyone know how I could identify this fuse or its rating so that I can buy a replacement? I've Googled but I can't find a schematic for the LDT65 PCB anywhere.
Thanks,
IMG_1.jpg:
IMG_2.jpg:
IMG_3.jpg:
Look on the end caps of the fuse. Should be some inscription there.
EDIT: now your pics have arrived.
Buy a new transformer, it may not be just the fuse. Fuses blow for a reason. And I'm not sure it is a fuse. Tx's are only a few quid now.
Its hard to tell from the pics but are you sure it is a fuse that has blown.
Most fuses have there breaking capacity written or engraved on them
Looking at the 3 rd pic there's a black component which is a diode is that what is burnt out i can't tell on the 2nd pic.
To be honest i would be reluctant to try and repair any think like that,Transformers usually have internal thermal fuses.
Is that just a transformer or does it have quite a few components because if it's a switched mode type then forget it things don't burn up for no reason.
andy
if anyone wants to see the pictures as they should be.
Usjes, when using diynot picture hosting, do not type brfore or after the picture.
You should copy / paste what you see in the [net] brackets
but agree, throw it away and buy a new one
