Apologies if I seemed dismissive of the advice. I know and appreciate the advice given is correct and the best thing to do but a 'proper' conversion is simply not practicable and would certainly be a lot more than just a few £'s - unless you know anyone who'll do a 'legal' conversion for less than £500...? No?
I largely agree with everything you've said except for this bit which is wholly incorrect an office is classed as habitable.
Granted. But it's only 'habitable' if I say it is when looking to sell. It can be anything I want it to be whilst it's my property. As said, if we sold then there would just be boarding and panelling there, i.e. a storage space.
It's a small attic, the height to the bridge board is only 6' so there is no freespace to raise a floor. As said, the joists are attached to the hanging beams below the purlins and the distance between is 2 metres, there is a partition wall direct centre below and the joists themselves are 5" (more than capable of taking a fair amount of weight - certainly a single person sitting on a chair on boards that are screwed across three joists each, given that the same structure on the other side of the attic is holding a 50 gallon water tank - I weigh a fair bit less than 500lbs of static weight).
The purlins are 22cm x 7 cm and mounted into the walls with the roof rafters sitting on them roughly half way down, I'm fairly sure they are capable of supporting a couple of desk surfaces attached to them and the wall itself.
I appreciate the extremes of temperature. With all the wind yesterday, it was 10 degrees up there. Lowest I've recorded (on my trusty max/min thermometer over the years) has been 5. I do expect it to get colder next month and January but an extra layer and heater will take the chill off. In the summer it maxes out just below 30 (50 or 60? - this is Wales, not Dubai
) and that was before we had the window fitted (NE facing) and also before we discovered the ridge vent had been blocked up with insulation...
If it does get too hot/cold then I'll have to look at insulation between roof and panelling but I'll see how it goes first. There's plenty of free air movement up there so I'm not worried about condensation, no sign in over 13 years of living here, and the dehumidifer/heater is more than capable of dealing with any caused by me being up there.
I do appreciate the advice and my thanks for the replies, my original question was merely pondering over boarding rafters with relatively heavy plasterboard - it sort of moved on from there (original wasn't answered by the way
