Guys,
Mate of mine has a oil burner and a stove with a back boiler both connected to his heating system.
He mentioned to me that some of his rads arent getting as hot as others etc.
I asked him had he it balanced etc and he mentioned that the stove and the boiler are @ different ends of the heating circuit each with their own pumps and if you balanced the system for say the boiler it wouldnt be balanced for the stove.
Are there a few hard and fast design rules here when you have 2 heat sources?
my thinking is that the outputs from both should be going to the one manifold and then split into zones etc.
Also when both heat sources are on...is there some clever device that can decide to say always take water from the back boiler once its hot otherwise turn on the oil boiler and vice versa etc.
Its a pretty new house but it sounds like it wasnt planned out very well...no thermostats in any of the rooms so im guessing the boiler is just cycling all the time.
Cheers,
Marty.
Cheers,
Marty.
