Hi all,
This issue has been on-going for a while now but with the weather getting colder, I really need it sorted.
I have an Ideal Classic FF250 boiler. It's worked ok'ish for the past 10 years that I've lived in my current house with the odd problem here or there. The CH pump was changed about 8 years ago and is now working fine too.
Initially, it stopped working and a boiler engineer replaced a broken fan inside it. Then in approx. November 2020, The heating and water would be switched on but before the radiators got up to temperature and before the water got really hot, the boiler would switch off. It'd then come back on again for a few minutes and then switch off again - would keep cycling in this way.
The same engineer changed the gas valve on it and it seemed to work better and get up to temperature.
Recently though, it's happening again. i.e. cycling.
I had another boiler engineer come over as the previous one has moved away. He looked at the boiler, (without opening anything) for a second then went up to where the tank is. He checked it with a magnet and told me that the boiler was fine and that they system was full of gunk and would need a chemical clean out and a new pump.
He said he couldn't do it there and then and that I would have to book it in with the office. On calling the office, they said the work would cost around £600 and that they couldn't do it till March time.
I wanted to ask if this is the going rate in East London and if changing the pump and the chemical clean sounds like the right thing to do for this issue? How would this fix the boiler cycling in this way? I can't see the connection? I asked the 'office' the same question but the lady on the phone couldn't answer it?
