Boiler and setting it questions
9 Nov 2016
Hi forum some or any advice would be very helpful, thanks:
  • How do I reset a boiler, is there a button or something I should look for or turn off the mains?
  • Can I reset a wireless thermostat and does it control the hot water or just the central heating?
  • Which way do I set the valves (left/right/halfway)on the boiler for the following:
  • CH Return
  • CH Flow
  • DHW Outlet
  • DHW Inlet
  • DHW flow switch what is the purpose if this?
  • Cold water Inlet (This turns all the way left and right about 5 turns each way, what is the turn it should be set at?
Have you just moved in and you're trying to work out how the system works? Name of boiler would help you search to see if there is a manual online somewhere which you could download and study at your leisure. Then you could come back here if you have further questions.
