Boiler at Risk
6 Jul 2012
Berkshire
Hi – this isn’t really a DIY question because I’m not qualified to carry out any work on my boiler, but I hoped for a little bit of advice.
We had our boiler serviced last week by our gas company – it was their initial inspection after we signed up for their boiler cover.
They slapped an at risk sticker on it because they say the CO2 readings are way too high. Fair enough, it is ancient (Potterton Flamingo II). They suggested that I should buy one of their carbon monoxide monitors as it’s a potential danger to me and my family, should the flue ever get blocked. They also suggested that I should buy a new boiler and arranged for a sales person to come round on Friday.
So, a few questions:
- I’m no expert, but I don’t think a carbon monoxide monitor would monitor CO2? (I’ll buy one anyway, but still...)?
- Wouldn’t any boiler (old or new) be a hazard if the flue got blocked?
- The sales-person who came round on Friday told me I’d need to get the pipe-work that runs from the boiler to the HW cylinder upgraded from 22mm to 28mm – does this sound right?
Many thanks.
You or the engineer may have been confused by CO and CO2.
The BG engineers gets commission of about £25 for arranging a quotation.
You do not need anything larger than 22 mm to heat the cylinder.
Why on earth dont you trust an independent ? We are less likely to cut you off as we dont get commission like BG etc..
Thanks a lot. Even the paperwork report that they posted says "CO2". Like I said, I'll get a CO monitor anyway for safety's sake.
I definitely wouldn't buy a boiler from BG (or any of the other companies) - they're much more expensive (I discovered when I replaced the boiler in my last house). I suppose they have to pay for expensive TV ads etc.
Thanks again for your help.
They have to make a profit for their shareholders!
You say he "serviced" the boiler, did his include the use of anything other than his flue analyser?
If he actually serviced properly the chances of excessive co or co2 would be rare from my experience
That's a good point - it was an inspection rather than a service. They inspect the boiler to check that they're happy to provide the boiler cover - I suppose they don't want to cover a boiler that'll be breaking down all the time.
Solution- get the boiler serviced
A co alarm is never a bad idea though
Is it open flued or balanced flue version?
Also if you don't mind me asking how much have they quoted you
For cover. There are very few parts on this boiler and it should be fairly cheap to maintain
As above, also
The salesmen are just that and I know a couple personally, I could write on the back of a matchbox what they actually know about central heating.
He may have been upgrading the pipe work depending on the size of your property in order to put the pump/28 mm controls in your airing cupboard.
I would get an independent engineer around to service the boiler and get him to give you an appraisal of the system
And if you feel the independent knows what he is doing then scrub the BG cover!
Part of the servicing is to set the CO² and measure the CO.
Yea ggry will take cover for anything. But when if breaks and the computer says parts are obsolete they won't repair it
