Boiler Buddy ......... Y/N?
6 Sep 2007
Lancashire
Does anyone use these ?
They worth the bother ........
Let the discussion begin ;)
PDF On The Subject
If you shop prudently you can get them a lot cheaper .....
Other than the capital outlay issue what are your thoughts :shock:
They work fine but they are not so easy to clean so a Magnaclean is likely to be better on a dirty system.
Tony
I think it looks quite robust and being transparent gives you a good indication when it has collected crud from the system.
I guess if you could afford both the magnaclean and the boilerbuddy then you have the added benefit of having a sightglass to determine when to clean the magnaclean. :D
Tony
You mean I can't just "In the dishwasher with you" ? ......... It works great on my cars hubcaps :?
i think he means that to open up the thing to clean out the black stuff, then put in back together, magnaclean on the other hand is a piece of cake to open and clean,
had a boiler service the other day where a early type maganaclean (flat bottom) and even on a clean system it still picked up stuff not loads but enough to show the customer and tell them what a good investments they got
