Hiya,
I have a bit of an urgent request for help if possible.
We have recently had our annual boiler inspection with Eon (as we have Central Heating and Boiler Cover with them). The guy from Eon has been out and has deemed our boiler unfit and capped it off.
We have previously had boiler cover with Powergen and in fact had our last inspection in January of this year when it passed fine (Powergen subcontracted their inspection work to local firms in the area). With Powergen moving to Eon we had to move to the new plan with Eon.
Anyway, it didn't go well - I had to show him where the ventilation was (otherwise he threatened to mark it as dangerous), he thought the central heating wasn't working (he hadn't noticed that the radiator thermostats were turned down) so he has capped it off because of three things:
1. Black soot within the boiler (never seen as a problem on previous inspections as it was just cleaned out)
2. Apparently the flume is not connected to the boiler correctly (again never picked up)
3. Electronic box inside the boiler is exposed (i.e. no cover - again never picked up)
I appreciate that he has to put our safety first but it doesn't install much confidence when I have to tell him about the boiler (and I don't know a huge amount myself) and that we had a boiler inspection not only 3 months ago which was cleared.
Anyway, we are now without central heating and hot water. His supervisor is coming out on Monday to assess the siutation (much from my complaints to Eon).
I appreciate that it is an old boiler and probably needs replacing at some stage in the future but I need some thoughts as to what to do (perhaps links to the legislation). Because it is an old boiler we won't be covered for full replacement on our cover plan - just a 5% discount for a new boiler.
If we have to replace the boiler, how much roughly should we be looking at for replacement and fitting? Is condensing boiler the way to go (we currently have a condensing boiler).
I'm a little annoyed at their approach - putting safety first I know is vital but threatening to cut my gas supply off to the house isn't very customer friendly!
Your thoughts would be much appreciated,
